Hi Guys,
Need some advise. We have the 2* peplink 380 model and 2 WAN links. Primary lnternet links is running on drop in mode via WAN 3 (the reason i use WAN 3 interface instead is because we want to have high available) and secondary internet links is via WAN 2 nat mode.
Hence, the firewall is default route(next hop) to ISP router via peplink. However, I noticed that the incoming traffic to internal server is not working as those server sitting behind the firewall (already have nat to wan 1 /27 subnet ip). Suppose the drop in mode the incoming traffic should not require any configuration? I did configure the inbound services but it doesnt seem to work…
Neither on the HA is working also as once the HA enabled the peplink is totally inaccessible.
Thanks.
