I can no longer access my Peplink 380 by the LAN port. I wanted to have access by the console but it is not also possible. Someone could help me by giving me the number of the DB9 console port ? (my email address:[email protected])
Web admin access was probably disabled by mistake. Are you able to reset your Peplink on the LED panel?
No I can not because the LED panel is no more readable
In that case we might need to resolve via our support queue. Did we buy through a local partner?
If so, please contact them to file a support case. We will then work with them to sort this out. Thanks.
i’ve the same problem.
Please open a support ticket for further investigation:
https://contact.peplink.com/secure/create-support-ticket.html
