hi guys i have the tmobile home internet G4SE MODEL and i bought the peplink 22g slim antenna so my question is ,in which order do i have to plug my antenna to my tmobile router necause the porta are labeled ant1,2,3,4 and the peplink lte1,lte2,wifi1,wifi2,gps so if any of you guys could tell me in which order i have to plug the cables i will appreciate it , thank you.
The TMO HI device you have has four cellular antenna ports. The antenna you purchased has two cellular and two wi-fi. If you want the “slim” design/model the product you should use is this one:
I would not recommend using the Slim 22G with the TMO gateway. It will “work,” but not very well.
Your Peplink Partner, or a Peplink Certified Engineer or Sales Specialist, will be able to help you.
