Hi Everyone,
i’m seeking help here. i want to upgrade the device which is currently firmware 6.3.4. as i check the firmware, all is the latest version which is 8.3.0. if i just upgrade it, could be any issue happen like missing configuration ?
because this upgrade like jump to the latest version. i worry if configuration will missing.
Unless someone has a better idea I’d:
- Save the config you are using under 6.3.4. (I’d note the file name to indicate it was the last under the old version)
- Upgrade to 8.3.0.
- Save the config again (noting first under 8.3.0)
This will allow you to back-out if necessary. But, frankly, I’d upgrade anyway rather than using a dinosaur FW version. There have been huge improvements between the two versions, as you may be aware.
