Hi folks, I’m looking at purchasing a Pepwave Surf device for providing a wifi hotspot in my RV whilst connected to campsite wifi or 4G. I have a question about using the external antenna, I was looking to connect an all-weather omni antenna to the roof of the RV, but is this likely to have a negative effect on the ability of the devices to connect to the Pepwave or does the Pepwave also have an internal antenna that is used for the local wifi hotspot?
Chris
PS in case it wasn’t clear, I’m talking about the Pepwave Surf-and-go device.
