Pep Wave Max Adapter is showing up as "Sierra Wireless WWAN Network Adapter" On Windows
Peplink Connection Manager isn’t picking up my Max Adapter and on Windows’s Device Manager is shows up as “Sierra Wireless WWAN Network Adapter”
When using it on a Raspberry Pi, it also shows up that way:
esteban@esteban:~ $ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 003: ID 1c4f:008b SiGma Micro USB Keyboard
Bus 001 Device 015: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 022: ID 1199:9091 Sierra Wireless, Inc. Sierra Wireless EM7511 Qualcomm® Snapdragon™ X16 LTE-A
And although the connection works, it has been working with the physical SIM, I want to tap into its eSIM capability, I need some help
