Main office is B380 with firmware 8.0.1. Remote offices are Balance One with firmware 8.0.1. Each device has WAN1 and WAN2 with different providers.
I am experimenting with the Pep VPN split tunnel feature. On main office I created three tunnels:
- Both WAN at priority 1
- WAN1 at priority 1, WAN2 at priority 2
- WAN2 at priority 1, WAN1 at priority 2
The remote is unchanged, still on single tunnel.
The tunnel works, it transfers data but the home page Dashboard shows tunnel 2 and tunnel 3 as “starting”. The “both” tunnel shows Established. Is this normal operation? I’m not worried about the Dashboard as long as the data is flowing as expected.
I have an outbound rule that should send certain data out tunnel 2. There is no rule for other types of data between the two locations so I assume it would use tunnel 1. How can I monitor whether the data is going through the intended tunnel?
