I try to mount a VPN between two PEP BALANCE 50, each with 5 ADSL lines.
I tried through the web console to each router and InControl via console: the tunnel does not rise.
I have a message: “Updating roads …”
I never met the similar problem with other BALANCE 50 (in the same configuration)!
In the error logs I have this:
Yet my 5 lines are UP on each side:
Do you have any idea ?
Thanks for your help.
Best regards.
