I want to filter a port at both TCP/UDP protocol, do I have to set up two separate rules ?
What exactly does involves using “IP” protocol in firewall rule ?
(naturally not “Pellin” but “Peplink”
ALex.
ALex.
Hi Alex, yes you would need to create two separate rules. The “IP” protocol field would be used for example by 47, GRE:
