Peer-to-peer Traffic over a Specific WAN link not Work
Hi
I have 2 internet connections.
  1. FWA 80Mbps Download, 50Mbps Upload
  2. ADSL 10 Mbps Download, 1 Mbps Upload
The FWA line has a monthly GB download limit.
In order not to use the GB of the FWA line, I would like to divert the p2p to the ADSL line even if it is slower.
However, I noticed that the download station (synology) only for p2p works only on the FWA line while it does not connect on the ADSL line.
If you download something from the internet it works, while p2p doesn’t connect. It worked with my old router so I think it’s a peplink router problem.
Also because when I force the connection to FWA the synology connects to the p2p servers.
What should I watch?
Sorry for my English.
