Packets per second question
Dear colleagues,
I am working at an event in Barcelona this week. 2 x FTTH lines combined with a 5G modem into a Peplink Balance Two. Fiber providers are Colt and Adamo
Colt works great, but take a look at the Adamo statistics:
What is happening there?
Every few minutes, signal completely dissapears.
Blue arrows show latency spikes and severe packet loss (7824.1 packets per second on the highest peak!)
but wait…
How many packets per second are being pushed out on a 17 Mbps RTMP stream? MTU value is 1440
Not an expert, but my math says this:
Packets Per Second (PPS)=Bandwidth (bits/sec)​ / Packet size (bytes)×8
which results in approx 1476 PPS
So how come are we losing 7824 packets per second? what am I missing here?
If anyone can shed some light on this topic, it would be appreciated.
You are using dynamic weighted bonding. The little blue downwards icons indicate WAN smoothing is active and duplicating packets hard. The big underlying issue with the ADAMO is the out of order packets. Speedfusion sees this as packetloss and resends the packets that don’t arrive in time, hence why speedfusion has enabled wan smoothing.
If you can add a little more receive buffer at the remote peer you should see less impact caused by the out of order packets but over all tunnel latency will rise.
The two little outages look like real data transmission issues, and that matches with the overall poor quality of the ADAMO circuit. It all points to a heavily congested fiber network with performance issues.
Set cut off latency on each WAN to around the 60ms mark so those nasty spikes on ADAMO don’t impact the tunnel.
