Hello guys. I have noticed for example that Fortinet or SonicWall router have a pakcet inspection feature, which is very helpful. Is peplink going to add something like that in the future??
You can do network capture on the router by visiting the support.cgi page. You can also pipe that capture traffic to a remote IP if you want.
As of Firmware 6.3, Peplink devices can send packet information to an external client, where it can be analyzed by Wireshark.
To enable this feature, please follow these steps:
1) Download Wireshark and Netcat
Please follow the links to download the programs:
Wireshark Packet Analyzer
Netcat
2) Enter Netcat Command
Once Wireshark has been installed, navigate to the command prompt and adapt the following command to your installation.
C:\nc\nc.exe -l -p 12345 | “C:\Program Files\Wireshark\wi…
