I have upgraded from a Balance 380 with v5 firmware to a Balance 580 with v6.1.2 firmware. I am observing some behavior with the 580 and v6.1.2 that I did not see with the 380 and v5.x firmware.
If I make a change in Network–>Inbound Access–>Services, I am prompted with the following message.
*Overlapped criteria. Your settings is overlapped with the existing Service(s), are you sure you want to save it forcibly?
*There is a list of services, their IP address assignments, and their protocols.
What is the problem with overlapped services? Is it really a problem? My device appears to be working as expected. Any insight as to what this message truly means and its implications for device operation are appreciated.
Thanks for reading!
