I I want to configure 01 IP (1 computer) to go out with 1 WAN on Peplink 750, how configuration
Hi @nhngan2001,
There are 2 steps to make this happen, first, I’d recommend reserving the DHCP IP address for the MAC address of the PC see screen shot below - reserving 192.168.150.25:-
Click the Network Tab, then LAN Settings from the left menu and in this case, I’ve clicked on “Untagged LAN” to bring up the following window
Once you have reserved the IP Address for the PC, you can then create the required outbound Policy - Network tab → Outbound Policy (from left menu) then click Add Rule:-
Then with the settings below, I’m forcing the PC with IP Address 192.168.150.25 to use WAN 2 only.
Hope this helps,
Steve
