We have a balance 20 on 8.x with approximately 50 devices and want to route a dozen or so of that number through a specific WAN port. Is the correct way to handle that with Outbound Policy with a rule for each of them or is there a more elegant way?
Typically you’d put them into their own VLAN / subnet and route based on source network. Or if using DHCP you could add dhcp reservations and identify them by using a /28 subnet in the policy. So assuming you have a 192.168.1.1/24 this rule would send all of these IPS 192.168.1.241-254 via WAN2
Using DHCP so I’ll give that a shot. I have A second Balance 20 for testing so…
I check back with results.
Thanks for heading me in the correct direction!
Thanks again!
Does exactly what was needed.
