Is there any possibility to do
Outbound Policy based on Starlink status? e.g. if mobile priority is turned on then a rule can be activated which is only letting essential traffic through? No OS updates etc…
Not natively on the device, but you can automate it using InControl 2 API to monitor Starlink status, then add or remove tags to the device that add or remove outbound policies.
