Hi, i’m looking for a bit of advice please.
We need to add some failover bandwidth via 4g to a venue where we can’t touch their current infrastructure.
All we can do is provide a Peplink router, a few LTE routers for data and plug into their WAN2 connection on a standard router set to failover, annoying as its not the way we do stuff, but hands are tied.
There will be an amount of devices connected to their router, if their fibre fails all internet data will be redirected to me from their WAN2 so on my peplink it’ll just show a load of data moving on a single IP.
My question is…
How does outbound IP:session load balancing work on a Peplink on this scenario? Is there a way to distribute a single IP’s sessions over all the active WAN connections without creating a speedfusion tunnel? I’m happy to make a bonding speedfusion tunnel if I have to but it will limit the overall bandwidth I could make available if it just load balances without it.
Cheers
Rich
