Ospf routing balance + hd4
Hi Everyone.
I need to know something about filter routing information to pepvpn remote device.
How can i filter routes that are learned for the balance by ospf to hd4.
i need that the hd4 doesn’t have that routes.
how can i do that?
The OSPF between both devices need to be up, because the balance needs to know the vlans in the HD4.
In HD4 i can configure the checkbox “send all traffic to”.
I attached the diagram
Hello aortega,
You can select routes that you would like advertised. The setting on the HD4 is located under Advanced > OSPF & RIPv2 > Route Advertisement > Network Advertising. Add any VLANs that you would like advertised over SpeedFusion/PepVPN. Any VLANs that aren’t listed will not be advertised.
Thank for your answer, but, what about the route that were learn by ospf, that option that you say is for direct connected network (vlan),
In the diagram that attached there is a router in the lan of the balance and that router advertise routes to balance.
By either not advertising the specific routes, or by turning on route isolation on the Balance - but that will affect all devices that connect to it via PepVPN.
There is no way to filter routes at the HD4 end that I’m aware of. .
Thank you very much, the isolation route is that i needed
