When you enable OSPF on the LAN side of a peplink that currently has a static default (0.0.0.0) pointed to the switch on the LAN will the balance advertise the 0.0.0.0 route as well as the other currently configured statics or will is suppress the 0.0.0.0 route to the OSPF neighbor by default?
Default route is special handle by our device. It wouldn’t advertise to SpeedFusion peer. Remote peer may need to enable Send All Traffic to the hub side.
