I know that firmware 6.x has OSPF support but I’m a bit hazy about what the functionality actually is, and I don’t want to switch it on in my production network without being sure
If OSPF is enabled… does the device…
Learn routes from local OSPF neighbours?
Advertise locally-defined routes (on the LAN settings page) to local neighbours?
Advertise routes learned from Speedfusion peers to local neighbours?
If (3) is true, that would be very useful for me!
I would like to know how the device selects which route to use if it has learned a particular prefix via OSPF and also from a Speedfusion peer.
Knowing the default cost is very useful. However I can’t see any way to modify the costs in Outbound Policy. (10,000 would be a very high cost in our network, so those would be last-resort routes only, and I want them to be first-resort routes!)
I don’t think there is one, but could I please suggest that you guys consider writing up a knowledge base article on using OSPF with Peplink in a heterogeneous network? I’m sure a lot of people would be interested, because it is potentially such a useful feature.
I see the new beta firmware has some more exposure of OSPF details in the GUI so maybe I should be trying that
The cost cannot be change. The route prioritization I mentioned above is using the Load Balance Algorithm like Weighted, Enforced, Priority and etc. The function is like static route which can used as workaround to prioritize the route.
