Openvpn to fusionhub: failed: Unknown error
Sorry - solved. I did not have the correct security group applied in cloud control panel and port 1194 was not accepting connections.
I installed new fusionhub. Under Advanced → Remote User Access I clicked
Enable
(x) OpenVPN
connect security refresh 60 minutes
authentication token lifetime (unchecked)
Connection / IP addresses WAN WAN IP Addresss
Port TCP (next block left default port in gray 1194)
Include OSPF Route unchecked
Auto-reset OPEN VPN (unchecked)
Authentication Local User Accounts
one username and password set
Downloaded OpenVPN file from the status page.
When I try and connect from Windows 10 OpenVPN GUI Client, it gets to:
Mon Apr 8 03:47:02 2024 OpenVPN 2.5.4 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 5 2021
Mon Apr 8 03:47:02 2024 Windows version 10.0 (Windows 10 or greater) 64bit
Mon Apr 8 03:47:02 2024 library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10
Mon Apr 8 03:47:02 2024 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25341
Mon Apr 8 03:47:02 2024 Need hold release from management interface, waiting…
Mon Apr 8 03:47:03 2024 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25341
Mon Apr 8 03:47:03 2024 MANAGEMENT: CMD ‘state on’
Mon Apr 8 03:47:03 2024 MANAGEMENT: CMD ‘log all on’
Mon Apr 8 03:47:03 2024 MANAGEMENT: CMD ‘echo all on’
Mon Apr 8 03:47:03 2024 MANAGEMENT: CMD ‘bytecount 5’
Mon Apr 8 03:47:03 2024 MANAGEMENT: CMD ‘hold off’
Mon Apr 8 03:47:03 2024 MANAGEMENT: CMD ‘hold release’
Mon Apr 8 03:49:10 2024 MANAGEMENT: CMD ‘username “Auth” “username-redacted-for-forum-post”’
Mon Apr 8 03:49:10 2024 MANAGEMENT: CMD ‘password […]’
Mon Apr 8 03:49:10 2024 Outgoing Control Channel Encryption: Cipher ‘AES-256-CTR’ initialized with 256 bit key
Mon Apr 8 03:49:10 2024 Outgoing Control Channel Encryption: Using 256 bit message hash ‘SHA256’ for HMAC authentication
Mon Apr 8 03:49:10 2024 Incoming Control Channel Encryption: Cipher ‘AES-256-CTR’ initialized with 256 bit key
Mon Apr 8 03:49:10 2024 Incoming Control Channel Encryption: Using 256 bit message hash ‘SHA256’ for HMAC authentication
Mon Apr 8 03:49:10 2024 TCP/UDP: Preserving recently used remote address: [AF_INET]IP-Address-Redacted-for-Forum-Post:1194
Mon Apr 8 03:49:10 2024 Socket Buffers: R=[65536->65536] S=[65536->65536]
Mon Apr 8 03:49:10 2024 Attempting to establish TCP connection with [AF_INET]IP-Address-Redacted-for-Forum-Post:1194 [nonblock]
Mon Apr 8 03:49:10 2024 MANAGEMENT: >STATE:1712562550,TCP_CONNECT,
Mon Apr 8 03:49:25 2024 TCP: connect to [AF_INET]IP-Address-Redacted-for-Forum-Post:1194 failed: Unknown error
and fails and loops again and fails to connect.
Any ideas on what I need to do to fix this?
