I’m looking for information about the max number of openvpn client that Balance can handle. I remember to see this number on datasheet but on the new datasheet it’s already removed.
Does anyone have the old datasheet ?..
Thanks.
Thanks.
@gusfrian.peplink, you should able to get the answer from compare.peplink.com, under the “IPsec/L2TP/PPTP VPN Functionality” section.
Choose your desire model(s) to find out the information.
The first question is “which Balance?” You may wish to go here to check the parameters of various routers. When you do so scroll down to the section entitled “IPsec/L2TP/PPTP VPN Functionality” and you’ll see an item called “Maximum PPTP/L2TP/OpenVPN Users” and there you find your answer!
