Actually, trying to solve issue of OpenVPN clients that are using the same network scheme as destination LAN (eg. 192.168.1.0/24). See attached images. When a VPN client connects, they are issued a 192.168.1.xxx IP address, which is a problem for anyone connecting from the same network scheme. Ultimately, I intend for clients to connect from any network, be issued a 10.10.2.x ip address and be able to reach resources on the default “Untagged LAN” on 192.168.1.0/24.
@ctsmetrony in the OpenVPN RUA settings, you can configure which VLAN for remote user to connect by changing the Connect to Network
