Hi I am using a PepWave BR1 Mini cellular gateway and want to test the OpenVPN client recently available on firmware 8.1.1.
I followed the steps described to the tee, purchased the license key. After adding the license key, the OpenVPN option under dashboard (always says disabled) with a text in the bottom claiming a WAN feature is available for activation. When you click on that link, it takes you to the network management webpage under Peplink and doesn’t really help in any way.
I then tried to upload an OpenVPN client configuration file but I keep getting an error ‘internal error, file checksum mismatch’. I did a file checksum and verified it is not the configuration but I think the problem is something else, perhaps something involving the activation of the license??
I did try the same configuration on different machines and had no issues connecting to my VPN - only had issues with this PepWave. I have uploaded portion of the configuration but I changed my IP for obvious reasons.
I am not sure how to proceed further. Any suggestions / advice would be greatly appreciated.
