Hi Community
I have problem with a Balance 20X is there anyway you can create client certificates on the router, instead of using username and password for authentication when connecting to the VPN.
And yes it does need to be OpenVPN.
Can i login SSH or telnet etc. to create user certificate and incorporate them into the .ovpn file ?
Kindly Regards
Glenn
