I have OpenVPN running with an access server in AWS. I can ping through from another network node (my laptop) through the access server to the Peplink but I can’t access LAN side (192.168.50.xxx) devices.
Hi @awoods, which firmware version are you using? Did you try the latest 8.4.1 build?
If problem still exist, would you open a support ticket to allow support team to check on the issue.
