I am using the SOHO and have configured a static route to my 4G modem:
I am connecting to an OpenVPN provider using the OpenVPN client on a Windows 7 machine that is connected via ethernet to the SOHO. I would also like to be able to connect to the 4G modem router config when on the VPN.
When I try to add the route, it adds it, but I am not able to connect to the 4G modem’s config page. Here is the output in the OpenVPN log that displays the route being added:
C:\Windows\system32\route.exe ADD 10.0.2.0 MASK 255.255.255.0 10.127.10.43
ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
Do I need to modify what I put in the OpenVPN config to get it to work in conjunction with the SOHO?
Thanks!
