Just started using Openvpn on a Balance 20. After adding 10 remote Openvpn users, any additional user that sign on has a very slow connection. I’m I using the right device? Is there a limit? Is there a better Peplink product? I would like to add 30 VPN at one time. I can’t get there with what I have. Thanks for your input.
What is the WAN connection on the Balance 20? If you look at the dashboard on the web ui of the B20 how much of that bandwidth is being used?
