HI,
I have 2 modules of model MAX BR1 MK2, what is the correct way to open communication between the two modules, which means that I will have ping between them.
Thank you, Shaked
HI,
Thank you, Shaked
Hi welcome to the forum!
That depends how they are connected. Do you mean if they are in different locations connected via 4G, or do you mean in the same place connected with a cable?
What are you trying to do?
Thanks for your feedback.
I’m interested to know the two ways you mentioned.
Can you detail how a connection is made in different networks and in one local network?
Thank you, Shaked.
