Open VPN Client With Separte Certificates & Key File
Hi, I am using a Peplink MAX BR1 Mini for a project that requires an OpenVPN connection. The OpenVPN server has generated several separate files, including a CA certificate, client certificate, PEM file, client key file, and an OVPN file. The OVPN file (.ovpn) is very brief and does not include any embedded certificate or key details. Anyone had experience this? since the the Peplinkl router only allow uploading the .ovpn file only
Can you just embed then in the OVPN file yourself? They’re just text files.
