My pepwave BR1 mini will only allow the internet to the 1st client that it connects to via WIFI. How do I change the mini to allow more than 1 client at a time?
That’s not the default behavior. If you factory reset it multiple users should e able to connect at the same time.
Did you turn on IP passthrough on the cellular WAN maybe? If you did, only one device would get the IP from the ISP…
