I wonder if it is possible to establish a connection to a server using the Peplink maxmobile using multiple links simultaneously.
One connection using several links
Lai
#3
Hi Ramon,
You can use multiple links at the same time for a single session if you are using Site-to-Site VPN.
If you are using only one MAX mobile router for Internet load balance, then single session will go across one of the WAN link only. But multiple sessions can go across multiple WAN links.
Lai
