Hi All,
I am looking for an external Omnidirectional 5G antenna which would be good for the marine environment. I would mainly need for it to be able to connect to Band n78 3500Mhz for Vodafone.
This is to be used by a Pepwave MBX.
Is there anything you guys have experienced to be good?
Thank you in advance ![:slight_smile: :slight_smile:](//forum.peplink.com/images/emoji/twitter/slight_smile.png?v=12)
Most marine installs I see use the Poynting 402 which is a very good antenna from personal experience.
Sounds great Martin,
I have 4 of them installed, but I didn’t realise they have 5G compatibility. I think they have advertised it better now.
Many thanks!
J
For all those watching at home, the Promarine 5311 is another excellent choice (although only single antenna instead of dual), in particular it holds up a bit better in the higher end of the 3500MHz band as the 402 drops away a bit, below unity gain. Spec sheet for the 402 here https://poynting.tech/wp-content/uploads/2020/02/TS-A-OMNI-0402-Rev4.pdf
