Hi guys,
Regarding the pepwave max mobile router -
Is there somewhere I can download old firmware? (is to track back an issue we’re having)
Appreciate any help!
Regards,
Chequer
Hi guys,
Regards,
Chequer
You can download the firmware upon registering your Pepwave MAX router on the Peplink or Pepwave website. You should be able to download our previous firmware release. You can follow the instructions here: http://www.peplink.com/index.php?view=faq&id=42&path=16
If you don’t have a Peplink.com / Pepwave.com website, however, you will need to register a new login.
Alternatively, you can contact our support team on your issue. I am sure they will be able to help you out.
Hi Matthew,
I did look, but unfortunatly this only lists the latest version.
I will try and find the support teams details!
Regards,
C
Can you let me know which MAX model do you own? and which firmware version version you are trying to obtain?
Thanks.
