Offline eSIM Provisioning via Smartphone App (Mobile Data)
Teltonika have just dropped a really nice offline eSIM provisioning feature If Peplink could integrate a similar capability into the Peplink Router Utility app etc it would be an absolute game changer for partners. We frequently deploy MAX BR series in environments where establishing an initial connection just to pull down an eSIM profile is a massive headache.
Allowing a field engineer, AV installer, or vessel captain to use their phone’s cellular connection to authenticate and push the eSIM profile locally to the Peplink device would save a tremendous amount of time and eliminate a major friction point in new deployments.
Since competitors are already pushing this functionality out to their users, it would be fantastic to see Peplink match or exceed this capability in upcoming firmware/app releases.
It’s almost like Teltonika reads these forums and fills in the gaps where Peplink hasn’t… :wink:
Yes, I feel the same way too… There is a lot going on here but we’ll catch up this thing. Give me some moments. Tell us what can be “magical” so we can exceed the competitions again.
I fully support this as well - current eSIM capabilities are limited and does restrict deployment sometimes (or makes it more tricky remotely).
Appreciate the swift response Alex, look forward to this !
