I know the cat5 plugged into the WAN is good. However, Status:WAN failed DNS test is what I get.
Do I need do something to my home router?
This is a brand new Balance 20x
Welcome!
It looks like you have a routing loop. Your router’s IP is 192.168.1.1 and your WAN IP is 192.168.1.2
What’s plugged into WAN1? Another router? You’ll need to change either the router’s IP or the WAN IP so they’re on different subnets.
Thanks!!! Worked!
