I’m new here but I have some experience with the Peplink products.
On the boat, I’m working on they have a Pepwave MAX BR1 MK2 with a local A1 sim card from A1. It works perfectly fine in the slot B but in the slot A it always says “No Sim Card detected Reload Sim”.
I tried another expired one and it does the same.
What could be reason except mechanical problem with the slot itself?
Whould this be a warranty issue after 9months if it is physical?
Any tip would help.
Simon
Device Information
Model: Pepwave MAX BR1 MK2
Firmware: 8.2.1 build 5082
