Good day all?
We have a pepwave Max Mobile Router which does not give daily data usage for previous days anymore
Attached is the screenshot of how the usage option looks like
Your help will be much appreciated
Thank you in advance
Levi
Good day all?
Levi
Which firmware version you are using? Please upgrade the firmware if it is not using the latest firmware version.
I am using Firmware 5.4.9 build 2101
Thank you
Regards
Levi Ileka
