Hello based on this version ,could you please provide me the correct OID and the key. for the cpu usage,
| Model | Peplink Balance One Core |
| Product Code | BPL-ONE-CORE |
| Hardware Revision | 1 |
| Serial Number | 192C-590D-16A1 |
| Firmware | 6.3.1 build 2256 |
Hey @afilalbadr2, welcome to the forum ![]()
That’s some mightly old firmware you got there!
OID should be .1.3.6.1.4.1.27662.200.1.1.1.3.1.0
You can get the MIBs for 6.3 from here: https://download.peplink.com/manual/peplink_balance_snmp_mib-6.3.zip
thank you for you answer with this config
If you’re using Zabbix, can’t you just upload the MIBs I sent you and select from those?
Also, you don’t have 6.0, you have 6.3.
