I see a bunch of uPnP stuff listed on my Balance One’s UPnP / NAT-PMP page. So I know some things are working using uPnP.
But the bit/litecoins are not connecting which use miniupnpc. When I run upnpc:
$ upnpc -s
upnpc : miniupnpc library test client. (c) 2005-2013 Thomas Bernard
Go to http://miniupnp.free.fr/ or http://miniupnp.tuxfamily.org/
for more information.
No IGD UPnP Device found on the network !
So the first question does the peplink support this? Anyone got this sort of thing working?
Noel_C
March 2, 2015, 5:35pm
2
It is work for me, I am using Balance 380 with 6.1.2 firmware.
$ upnpc -s
upnpc : miniupnpc library test client. (c) 2006-2011 Thomas Bernard
List of UPNP devices found on the network :
desc: http://192.168.1.1:34552/rootDesc.xml
st: urn:schemas-upnp-org:device:InternetGatewayDevice:1
Found valid IGD : http://192.168.1.1:34552/ctl/IPConn
Local LAN ip address : 192.168.1.122
Connection Type : IP_Routed
Status : Connected, uptime=1108s, LastConnectionError : ERROR_NONE
Time started : Tue Mar 3 17:10:46 2015
MaxBitRateDown : 10000000 bps (10.0 Mbps) MaxBitRateUp 1000000 bps (1.0 Mbps)
May I know what firmware are you currently on?
Model: Peplink Balance 20
Firmware: 6.1.2 build 2717
and
Model: Peplink Balance One
Firmware: 6.1.2 build 1597
upnpc : miniupnpc library test client. (c) 2005-2014 Thomas Bernard
Something interesting to note though… is our copyright dates. What version are you using? I’m using 1.9-4.fc21 and 1.9-1.fc20
Here’s the discussion on the miniupnp forums: miniupnp.tuxfamily.org :: View topic - Peplink Balance One and No IGD UPnP Device found on the netw
Just for completeness I tried using multiple versions of upnp:
miniupnpc-1.2
miniupnpc-1.6.20120509
miniupnpc-1.7.20120714
miniupnpc-1.9.20150206
Also tried with Oracle Linux 6.4, Ubuntu 13.10, Fedora 21 and Fedora 20.
Same results.
Michael_Carter:
miniupnpc-1.2
Same results.
Hi Michael,
Since you have opened ticket on this. I will follow up from there.
Thank you.
