@Legionetz Because the DNS traffic issue was not resolved after applying the firmware. Maybe I need to default to factory → apply the update and see if that helps. I have a peplink rep on the ticket but not a lot of help beside offering build4929
FYI - we’ve been doing some digging, and the AT&T issues seem to be widespread and not just impacting Pepwave routers.
The best theory I’ve heard is that it is AT&T’s HTTP proxy servers that are locking up after a certain period, since when the connection drops web traffic is impacted but it seems that already established VPN tunnels stay up, and other protocols (like IMAP) still work as well.
I think this is primarily on AT&T to fix - but it would be great if Pepwave routers could detect the situation and reset the cellular modems. Re-establishing the connection fixes things every time.
Thoughts?
- Chris
Thank you for updating the status here and very appreciated that.
We do see the same behavior for some of the customers that using AT&T that HTTP & HTTPS traffics no longer able to route (Not all websites).
From the analysis, we confirmed the HTTP/HTTPS packets is sent but not getting reply from remote servers. We also setup some test HTTP/HTTPS server to confirm whether the HTTP/HTTPS packets sent are reaching to the remote servers but the results is negative that the traffics sent is not even reach to the test servers. That shown that the issue is on the service provider level.
Do you tested the WAN health check HTTP method ? This should triggered the WAN health check failed and cellular WAN will be reset after failed sometimes.
We have 10+ MAX BR1 ENT that started doing this.
We have ATT sim cards. Grandfathered accounts.
The pepwaves will stop passing web traffic (yet I can still log into them remotely and they show good on smartcheck.
Also I can ping 8.8.8.8 from a laptop behind the pepwave… just can’t pull up a website.
When I reboot the pepwave it comes back up working.
If you look under STATUS->WAN QUALITY->CELLULAR the “latency” says “no latency”…
Just a stray thought: Since this seems to be AT&T throttling (essentially) HTTP[S] traffic, try routing that traffic through a speedfusion connection to a SpeedFusion (solo) server or a SpeedFusion Cloud (thereby avoiding the HTTP[S] ports for the traffic).
Please report back.
S
Yup exact same issue here. I’m able to remote into the network and reboot the device via web admin.
Hopefully you have a ticket going…
Its not a throttle thing. The internet straight up stops working. Like if you go to google chrome and go to www.google.com it will not load. BUT I can ping 8.8.8.8 (google dns server).
I can also remote into the pepwave from another location. If you go into the WAN quality reports the “latency” blue line just stops. But the cell signal is still good…
The moment you reboot the pepwave it all works again
Yes, it’s getting old. It seems to happen about every two hours or so.
Instead of a reboot, I just toggle the 3G/LTE selection and it forces it to reconnect. The reboots were getting too tedious.
i’m having the same issue and had created this related thread
i had the problem again about 2 hours ago; here are the details. let me know if there are other tests i should be adding:
Date and Time: 7/30 5:54pm
Does the problem occur on multiple client machines? YES
Can you ping google.ac (i used a new domain, that i’ve never been to for each step) from a client computer? YES (a lot of times in the past i’ve not been able to do this)
Can you traceroute google.ac from a client computer? YES (a lot of times in the past i’ve not been able to do this)
Can you ping google.ad from another client computer? YES (a lot of times in the past i’ve not been able to do this)
Can you traceroute google.ad from another client computer? YES (a lot of times in the past i’ve not been able to do this)
Can you connect to devices via ports other than 80 and 443?
SSH (on port 6xxx)? NO
NTP (TCP port 13)? YES
cat </dev/tcp/time.nist.gov/13 -
SFTP (port 22)? YES
sftp [email protected] (password is password) -
WIFI Call - interestingly, I got an iphone wifi call during the outage, and it came through and worked no problem… so I assume that doesn’t use 80 or 443??
Can you connect to the peplink modem and login as admin? YES
Can you ping google.ae from the modem? YES
Can you traceroute google.ae from a client computer? YES
Anything relevant in the event log? NO
I downloaded the diagnostic report in case it’s needed in the future
Good to know about the pinging. When it first started happening with, I swear that I was able to do it from my Windows laptop but couldn’t get the browser to open any URL. Then it became 100% packet loss, so I just assumed the first times were a fluke. I was also able to ping from the modem.
ok, so my test results over the last 3~ days are consistent with the report below and the previous report i posted. i get the same results each time…
interestingly during the outage google.com loads, and searches work… but no other website i try work (though i only tested around 10~). i know for sure i’d tested google.com in the past and it did NOT work, no website i tried worked - so i’m not sure what changed and why that one site works consistently now but no others do. i also don’t understand why sending slack messages failed, but i received messages…
Date and Time: 7/31 8:57am US ET (it also happened again just now, same results)
Does the problem occur on multiple machines? YES
(e.g,. Your laptop, phone, other machines, etc all can’t connect to the internet)
Can you ping google.com.af from a client computer? YES (34ms latency avg.)
Can you traceroute google.com.af from a client computer? YES
Is it all websites? Do any work?
- I can search Google.com, pages load, search works (i can’t view cached versions of pages though, just search)
- No other sites I tried work or load: http://wikipedia.org/ https://yahoo.com/ https://fast.com/ https://www.peplink.com/ https://drupal.org/ etc.
- Oddly, me sending slack messages failed - but I did receive a slack message from someone during the outage (and my retry on the send also failed after this). not sure why one would work, but the other wouldn’t.
Can you ping google.com.ag from another client computer? YES (53ms avg.)
Can you traceroute google.com.ag from another client computer? YES
SSH? NO
SFTP (port 22)? YES
Can you connect to the peplink modem and login as admin? YES NO
Can you ping google.com.ai from the modem? YES (29.4ms avg)
Can you traceroute google.com.ai from a client computer? YES
Anything in the event log? NO
I downloaded the diagnostic report just to have it…
Does the problem resolve itself? No (after 15 min i forced 3g only, it came back online, and i went back to forcing 4g only; faster than rebooting )
Just wanted to chime-in as I posted in the RC3 thread that I noticed something funky with AT&T. In the location I am in, I have never seen 3G. I loaded the 8.1.x RC firmware and started seeing 3G quite frequently. Before it was always LTE-A or LTE. I thought it could be the RC firmware or perhaps just coincidental timing with when I decided to load the firmware and its actually a cell tower/an AT&T issue? But this seems pretty widespread… although its not unheard of for cell tower radios/firmware to have issues with certain radios in client devices (I saw it happen once before years ago).
I was experiencing constant drops on my WiFi calling which led me to setup Speedfusion Smoothing. I never had issues with constant drops before. I could drag the cellular connection to disabled and then re-enable it and it would get LTE-A or LTE. Running a MK2. BTW, we’ve had some of our hottest days in the past week or two… wondering if temps are playing a role…
Perhaps someone wants to start a thread at: https://www.howardforums.com/forumdisplay.php/378-Data-Cards or https://www.howardforums.com/forumdisplay.php/50-AT-amp-T ?
Hi all, same exact issue for me as described in this thread. I spent $300 and replaced the Pepwave Max with a MoFi, and the issue still occurs. So it it definitely an AT&T issue.
I was told by my carrier that it’s due to increased usage with work at home, but if that were the case wouldn’t it have been going on prior to now? June 28th it started for me. Starting to think AT&T is having a much bigger issue affect fixed wireless installations.
@Matthew_Rice: I don’t think I noted what plan you are on – you may have said and I missed it. Is it a plan intended for use in a router or hotspot? Or is it a “tablet” plan or a SIM intended for use in a phone? Pre-paid or postpaid? And, can you say (in general terms) where you got it?
I am now noticing tons of disconnects on AT&T whereas I never noticed this before…
@ Peplink support team ticket # 20070808
PS. I started this thread on HoFo: https://www.howardforums.com/showthread.php/1919940-Anyone-noticing-connectivity-issues-the-past-few-weeks
For me, my plan is a data only plan, intended for use in data only devices, not intended for use in a tablet or phone. It is post-paid. Obtained from AT&T directly.
@Rick-DC I got the plan though mobilemusthave.com but it’s a reseller of ezmobiledata.com, I presume it’s for hotspot use only but there’s not a lotta info there. I’d take suggestions on another plan if there’s something better.
P.S. I live in a town that has about 2000 residents, and AT&T only arrived here within the past year. I don’t think there are any other AT&T users nearby, it’s not a popular plan for this rural area. I think they built it as part of the FirstNet roll out. So tower congestion isn’t a factor IMO
Is there any chance this is regional? I am traveling and this only started when we came into New York state. That was somewhere at the beginning of July. We are in Vermont now and still having issues. We do get deprioritized on occasion, but usually the rural towns are much better like you say.
I have mobilemusthave.com plan as well.
