Hello folks! It seems that you have an active community here, and I just wanted to throw my use case out there and see if somebody could recommend a system. Honestly, I’m a bit overwhelmed by the catalog and feature sets of every product that peplink is selling right now.
Looking to put together an HD video streaming kit that can be sent around to different places around the world and still get a “decent” connection. Obviously this will depend on carrier and signal more than the transceiver, but band coverage is important enough for it to be listed as a desired feature. I’ll have the ability to do signal mapping and prepare relevant SIMs before the unit gets shipped to a location, though these places can be anywhere on earth, so the most band coverage is important, and the possibility to hit 300Mbp+ is ideal.
A dual modem for failover or flexibility for “real world” signal situation on the far-end is required, though bonding and pepwave’s VPN service is something that I don’t think I can invest in right now, and isn’t needed at the moment.
A unit that boots as soon as it receives power is ideal, so that it can be tucked away and cable managed but still work when the whole unit it’s connected to is plugged in.
Needs to have an integrated Access Point, though this is mostly for connectivity of IOT devices, and the majority of the bandwidth will be directed via Cat6 to a control computer.
Any ideas? From the few days that I’ve spent looking through product manuals, I’ve been looking most heavily at the Max Transit Duo systems, but it’s really difficult to compare things because there aren’t really prices listed in places I can find, and I’ve only heard that the Max Transit systems can be somewhat expensive.
Thoughts? I’m sure some of you are quite pleased with your products and would love to tell a newbie like me all about them
