I have a newbie question regarding architecture of IP tunnels, sorry for asking !
I hope it will help other in the future as well.
I have a project where I need to connect 4 outdoor boxes containing PCs together.
1 Box is “the master box” because everything is physically connected to it but all PCs should be able to communicate together.
I need to have secure IP tunnels for everything that runs “outdoor”. There can be a few hundreds meters between boxes and I can’t have someone connect as a “man in the middle”.
The master box will also be connected to a remote office via LTE.
Is it possible to built this kind of network architecture ?
I guess I will need multiple virutal IP on the Peplink router on the same physical port, is that possible ?
The Peplink router I want to use only has 2 or 3 physical ports. Can I use a switch “in front” of it to connect to 4+ location ? Considering all endpoint have a FW that can support IPsec tunnel ?
Thanks for the help !
Best regards,
