I have set the Admin access to LAN only and https, but when hardwired into the router the browsers denies the https connection and defaults to http. I can log into the router fine.
Also, after logging into the router wifi and disconnecting the Ethernet I can still log in. Is this normal? I’m assuming that denying the remote admin login applies to other networks outside mine.
Thanks Martin. I do hit Apply after saving changes. Basically, my goal is to only allow admin login via Ethernet over https. Is that needed if I am connected via Ethernet?
How can I limit access to a single Subnet/Vlan? or like a single computer?
I just wanted to say thanks Martin. I got it to work. I literally spent all day wrapping my head around everything, but what better way to learn. These routers are pretty solid. Cheers!
