New to Pepwave...Sim Card?
On a whim I bought a used Pepwave MAX BR1 mini LTE router for $40. I would like to add AT&T to my internet connectivity arsenal. What do I need for a VERY inexpensive sim card plan to test it before I approach AT&T for service. Thanks!
All you need to do is go to USMobile. They have pretty good plans. The only issue with AT&T is that you need to change the APN setting in the Peplink.
And I believe you set APN to “broadband”…??
