Looking for some guidance on how to set up properly my wifi connection. Did a firmware update and it hasn’t been the same. Also under the AP connection, it is stating that the LAN is untagged. Don’t really know what this means. Thanks for any help.
Welcome to the forum.
Untagged lan is the default lan and is fine.
Do you have the wifi turned on on the dashboard?
Do you have a wifi ssid/name and password setup?
Do you have the wifi antenna connected and is broadcast turned on?
If you are still having some issues post some screenshots.
