New Security requirement so which unit if any will work?
I currently have a UBR LTE. Incontrol says WPA3 is an option. The router however only says WPA2. The other issue is that it would seem that all SSID’s have to run at the same speed. Here’s my issue though and any solutions would be great appreciated, preferably I won’t have to resort to adding yet another router to accomplish this.
  • work requires WPA3 for the Palo Alto VPN connections
    *I have Starlink & Cellular connection bonded alongside SpeedFusion this works as expected.
What’s missing:
I have IOT devices that need to run at 2.4 WPA/WPA2. I have desktops that for performance and security need to run with WPA3 and 5Ghz or switch to 2.4Ghz.
I’ve been told by support that the UBR LTE cannot support multiple SSID’s running on different freq.'s so how do I get all this in one box? Support for WPA3 mixed would solve all my issues but I don’t see that in the works.
if the ubr doesnt support multiple SSID, then upgrade to a newer product or get an external AP. i have 100+ devices and have only 1 that requires wpa2. i created a separate SSID just for it.
