I purchased this to use with a single sim card, Starlink and campground wifi. I added the software license upgrade a few days later. The event log shows that the feature pack was added a few days ago. I now see Wifi Wan options. I have tried on both 2.4 and 5 ghz to add our campground wifi to the setup and it will never connect. The event log doesn’t show incorrect password. I did change the password so it was wrong to verify that it would show up and it does. I changed it back and it never connects.
My bigger frustration is no WAN option showing up. I have my Starlink plugged into the WAN port on the back. The led on the router does light up green on the WAN port and does blink frequently as I would expect. But it doesn’t show up on the dashboard anywhere as an option. Is there something else I have to do to get that option to show up? Is it possible that the license upgrade did not give me what I need for the lan port to work as an input?
Firmware 8.2.1 Build 4920
Feature Activation lists, Feature Pack for MAX BR1 Mini
Del
