Your APN is likely correct – good work checking that. Here’s a screenshot from one of our customers’ devices this morning. “Network Mode” usually works on “Auto.” You can also try “T-Mobile.” Failing that it sounds like a provisioning issue which only T-Mobile will be able to resolve. And, if that does not work, I’d suggest contacting the Peplink Partner from whom you purchased the device for help.
