I have a brand new MAX BR-1 MK2 with latest firmware 8.0.2 installed. I inserted an activated SIM card (t-mobile Germany, 4G) and the router does not recognize the SIM card at all. In the log is says Cellular SIM card inserted in SIM slot A, but the device says in WAN settings SIM Card A “No SIM Card detected”. Also the LED for cellular on the router is off.
Pre-Conditions:
SIM card is acticated and works e.g. on my mobile phone
SIM has form factor 2 (mini SIM)
SIM is inserted in Sloat A with contacts facing down, small cutted edge goes in first
PIN is correctly entered
latest firmware installed on MAX BR-1 MK2
tried Slot A and B, no difference
tried different SIM card of different providers, no difference
modell name: MAX_BR1_4141_SO442-016
Questions:
Is it possible, that the cellular feature is somehow disabled on the device?
If yes, how can the feature be enabled?
If not, what can I do to have the router recognize my SIM card?
I assume, that after inserting the SIM card, I should see e.g IMSI, IMEI, etc. on the admin interface?
It sounds like the SIM is not seated properly. When you inserted the Sim in slot A (copper contacts face down, flat edge pointing out) did you hear and feel a positive click when it was pushed in?
thanks for your reply. SIM is facing with contacts down, when inserting into slot A, and facing up, when inserting into slot B. And yes, I feel the positive click (snap). SIM has the right form factor 2 (FF2, mini SIM). What do you mean with flat edge? The small cutted edge goes in first, I would assume that this is the natural way of inserting the SIM.
But I can try turning it, so that the cutted edge goes in last.
Just curious if you found a solution. I have a pepwave and use the at&t sim and it works fine. But I have a T-Mobile data plan for back up and when I insert the sim it does not even recognize it is in the slot.
I was having the same issue: SIM Card not detected. I’ve had my prepaid ATT card inserted and operational for 2 months until I ran out of data before the end of cycle. I called ATT for a “bump” and got 2 more GB of data before my renewal in 10 days, but the Cellular 2 Slot A still read “SIM Card Not Detected”, so I viewed the Status/Event Log and noticed the event “Cellular 2 SIM A hits bandwidth usage, stop data session”, followed by “Cellular 2 SIM A disabled, switching to SIM B”. This occured because I had the Bandwidth Monitor enabled under the Detail settings from the Dashboard. To fix, I disabled this setting and rebooted the router. Cellular 2 SIM A is now detecting my SIM card.
I’m also having this issue with AT&T sims in a Max Transit Duo. The sims work fine for a while, then the router just shows “no sim detected.” If I shut the router off and reseat the sim, it works again, but only for a while.
yes. on my br1 pro 5g i got the no sim detected error. it worked fine on firmware 2 so i simply reflashed firmware 1 and that fixed it. seems to be firmware got corrupted. possibly an exploit. just guessing but maybe because i had esim enabled with no esim account active so i disabled that just in case.
